It is currently Mon Aug 11, 2025 4:58 am
PostPosted: Fri Dec 09, 2016 10:16 am
First name: Jonny
Last Name: Fifield
Looking to end up with this from 4/4 or 8/4 rough stock
Some kind of jig to get inner and outer radius?
Any help here would be great
"Practice enough till the results aren't hopes but expectations" forum member Peter Havriluk
PostPosted: Fri Dec 09, 2016 11:57 am
I just cut 16 wedges at 22.5 degrees, superglue them on a 1/32 ply backing board (mounted on mdf with double sided tape) and run the lot through a 10-20 drum sander.
Then use a wells-carol circle cutter to cut out the rosette.
PostPosted: Fri Dec 09, 2016 12:52 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Like Colin said. Pieces pre-cut to finished dimension don't always stay that way.
Alex
PostPosted: Fri Dec 09, 2016 7:23 pm
First name: Trevor
Last Name: Gore
City: Sydney
I'm guessing that Michael did all those cuts on a bandsaw. Maybe a sub-table with a pivot pin and feed stock with a couple of holes to give the inner and outer radius. Maybe just free-hand following a line. "Square" the ends of the thick segments then slice them into multiple thin ones. To build a rosette would require the ends to be fine trimmed to fit, then glued down (either in the top or on a suitable substrate) and then the inner and outer radii trimmed with a router and the surrounding purling lines fit in the channels just cut. I can't think of an easy way to pre-cut them in bulk with sufficient accuracy to get a perfect slot-in fit.
http://www.goreguitars.com.au
PostPosted: Fri Dec 09, 2016 8:01 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Here's another vote for cutting wedges, assembling them in a ring, and then cutting the inner and outer circles with the circle cutter of your choice.
PostPosted: Fri Dec 09, 2016 8:40 pm
David Russell Young's book shows a drill press set-up to do this for a pearl rosette, but the same system should work for you.
Brent
These users thanked the author bftobin for the post: edstrummer (Thu Dec 15, 2016 4:19 am)
PostPosted: Sat Dec 10, 2016 8:55 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
In the video justin his assistant is cutting down the edges of the segmented sections either using a block with sandpaper or slowly rotating a disc sander to get the correct angle so the segments will butt against each other with a clean butt joint
PostPosted: Sat Dec 10, 2016 12:25 pm
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
OLF sponsor Eric Schaffer has a video on his free builder tips on how to make a slick jig for rosettes. I built one and it works great, especially for segmented rosettes. http://www.ericschaeferguitars.com/cour ... -acoustic/
Brad Hall
Mystic Dawg Guitars
PostPosted: Tue Dec 13, 2016 10:19 pm
No need. Rout a trough slightly oversized. Miter and glue the pieces in the trough. Level. Make a trammel base with two center points for an inner and outer band. Rout and glue in the bands with a gauged bit, level.
PostPosted: Wed Dec 14, 2016 9:50 am
First name: Jonny
Last Name: Fifield
any pics to help with the steps and show the end result?having a hard time to visualize this
PostPosted: Wed Dec 14, 2016 4:25 pm
What you're doing is cutting the radius in situ. You mitre and glue the oversized blanks into a trough of a set width/diameter in your top, level. You then presumably are putting an inner and outer band, so you need two different radius cuts. Make a base plate for your laminate trimmer or router with two separate holes for whatever size pin you cut your trough with, and that will give you those two cuts. Remember when laying out those holes that you're measuring from the pin to the inside of the bit for the outer ring and to the outside of the bit for the inner ring. This is because you want to define the radius of the cut so you're making the cuts where you need the radius to shape your veneer. Now rout troughs with a sized bit and set in and glue your bands. Level. I don't have any pictures. For example, my rosette is a 1/2". Seal the trough with sealer to prevent the CA from staining the endgrain of the top. I inlay tiles that just fit into the trough and I glue them one at a time to make sure for a good miter with a dab of thick superglue. Once they're all in, I flood it with CA and make sure its locked in. (If you have a material that's prone to staining from CA, you can use a combination of Hide glue on the edges and a dab of thick CA for the bottom.)I level on the thickness sander, come back rout the troughs for the bands, press those in and flood again with superglue. If it's my abalone rosette, I'll cut that trough when I cut the bands and inlay everything. Flood with CA, set aside for a few hours to cure, and level.
I have Bosch Colts and my base is simply 3/8" acrylic with holes to mount it to the router base, a clearance hole for the bit and then two holes about which the pin will ride to cut the two channels. They're offset from one another so you don't weaken the base in that area.
PostPosted: Wed Dec 14, 2016 7:05 pm
First name: Jay
City: Bothell
State: Washington
What I do is similar to what dberkowitz describes except I do the tile assembly away from the guitar top and then install the completed rosette ring into the top. I think this is basically the same approach Colin uses.
These users thanked the author J De Rocher for the post: ernie (Wed Dec 14, 2016 8:42 pm)
PostPosted: Wed Dec 14, 2016 9:21 pm
I do it the same way Jay does it
PostPosted: Wed Dec 14, 2016 9:43 pm
Steve, just curious as to how you remove the ring in one go and how you adhere it for assembly/routing
PostPosted: Thu Dec 15, 2016 7:27 am
Good questions. I've tried several methods but the one I use now is to build the ring on 1/64" (0.016") birch plywood using whatever glue I feel like using but usually CA. Double-stick tape holds the plywood to a 3/4" plywood base to route the circle with a Wells-Karol jig. When the ring is complete it is easily released with Naptha. The 1/64" birch ply holds it together very nicely and is something I learned from Todd Stock. I install the ring into a 0.050" deep cavity in the top and then add inner and outer rings to finish.
These users thanked the author SteveSmith for the post: dberkowitz (Thu Dec 15, 2016 8:21 am)
PostPosted: Thu Dec 15, 2016 9:11 pm
Last Name: Sollod
I do it the same way as Jay and Steve. I've been using poster board to glue the pieces to and when I'm done I turn it over and scrape the poster board off with a razor blade... Where can you get 1/64" birch ply?
www.swiftcreekguitars.com
PostPosted: Thu Dec 15, 2016 9:19 pm
I got the the 1/64" birch ply from Amazon but I have also seen it at one if the big hobby stores.
Sent from my SM-G930V using Tapatalk
These users thanked the author SteveSmith for the post: J De Rocher (Thu Dec 15, 2016 9:46 pm)
PostPosted: Thu Dec 15, 2016 9:58 pm
First name: Alex
Last Name: Kleon
City: Whitby
I used the 1/64" ply, and 1/64" maple veneer that comes in a 6" x 99" roll. The veneer was way cheaper!
Alex
These users thanked the author Alex Kleon for the post: SteveSmith (Fri Dec 16, 2016 10:08 am)
PostPosted: Thu Dec 15, 2016 10:10 pm
First name: Alex
Last Name: Kleon
City: Whitby
Here's one using 1/64" maple veneer as a backer.
Alex
PostPosted: Thu Dec 15, 2016 10:38 pm
Last Name: Marcq
City: Allenstown
Zip/Postal Code: 03275
This is my first radial rosette under construction for an octave mandolin, it's easier than I thought it would be. The tiles are CA'd onto sturdy cardboard (and to each other..) from the back of a notebook binder. I take classes with Alan Carruth, and his method is not to release the ring and then inlay it into the dado, but to level what will be the bottom, flip it over and glue it in, then plane/scrape off the cardboard. I'm a little antsy doing it this way because the show side is down when it's being made, but what the heck, go for it. I'll know how it worked shortly...
PostPosted: Thu Dec 15, 2016 10:39 pm
First name: Jay
City: Bothell
State: Washington
Alex - I like that rosette a lot. That's the first one I remember seeing with 8 tiles. The book matching is really cool.
PostPosted: Fri Dec 16, 2016 11:28 am
First name: Alex
Last Name: Kleon
City: Whitby
Thanks, Jay. If I had done 12 or 16 tiles, the benefit of the book matching would have been lost, at least, in my opinion. Plus doing 8 tiles is like half the work, right? :D
Alex
Users browsing this forum: No registered users and 47 guests
